LCD on ION not displaying correctly after update
just updated my ION to EOS v 3.1.2 build 20 and after the update the LCD does not display the letters correctly. it's like cut in half , zoomed to small and different font? So not really legible anymore.
It is on the console and the fader wing
any ideas?
  • This is an old message, but I encountered the same problem today after updating to the latest software. I was in working in 3.2.5 without any problems. When I start the software in 2.9.2 mode it works fine. Is there a solution available because I really want to use the functions in the last 3.0 versions... In already tried downgrading to 3.2.5 and earlier but without succes...
  • Hello   I'm having trouble following.  It seems that you are saying:
    - In v3.2.5, you have no problems - the text is legible.
    - In v2.9.2, you have no problems - the text is readable.
    - You want to use a version from four years ago (v3.0.x) but it is appearing scrambled?
    - And then you say you went back to v3.2.5, and it is scrambled?
    Is your console an Ion Classic and is your fader wing a Universal Fader Wing, as in this original post?
  • Hey Matt,
    thanks for your reply.My message was indeed a bit confusing. I'll try again
    I updated a Ion Classic with a universal fader wing from 3.2.5 to the latest software to 3.2.10. After the update the LCD screens were like the pictures above.
    I tried to downgrade back to 3.2.5 and even further down to 3.1.3 but without succes, the lcd's kept the same error.
    When I start the software in 2.9.2 mode the LCD screens are correct.
    I hope this clarifies my problem.
    thanks in advance
