Patch: Curve on parameters
3.1.2 Ti, probably older
In Patch > Attributes i wanted to assign a curve to multiple parameters. Chan 1 Curve Red Green 901 Enter will only put the curve on Red, but not on Green. and because it's failing silently it took me quite a while to figure out.
if the console accepts the syntax with multiple parameters simultaneously it should actually put the curve on those multiple parameters.
thx, ueli
