Some macros not correctly editable
If you write a macro using the learn function and tap the go or go back button of a playback (Cue loaded), the playback-funtion of the macrotext is displaysed blue in the macro editor. If you then want to change the number of the cuelist that is being triggered, it doesn't work, because the new text is displayed in gray and the macro doesn't work any more. I think that bug exists since version 3.1.2
I'm running version 3.1.3 Build 8
