Images organized into folders and saved in a showfile pre-3.1.4 will be removed from the folders and placed in the "root' of the image organization panel after a showfile is upgraded to 3.1.4
Appears on both Apex 10 and Nomad PC.
I did not see this happening in a quick test. Would you be able to send us an example showfile that was saved prior to v3.1.4 that does this when you open it? Preferably this would be a showfile with just a couple folders/objects on a Magic Sheet rather than a typical full showfile.
I'll see if I have time to pull one together. It would involve me downgrading a machine to test so I may not be able to generate a file right away. I can send you the showfile I noticed it on for sure if that will help. It happened with the same showfile on 2 separate machines.
I would be happy to look at the showfile it's happening in so long as it has nested/foldered images in 3.1.1 and they pop out in v3.1.4.
Ok, I will email you a link to the showfile
