Problems after upgrading to Eos/Ion 1.7
I installed the new version 1.7 yesterday.  Today I went to re-program our service (I have 3-4 groups of cues I use for different services).  I use one type of gobo from cyberlights through about 12 or so cues, switch to another gobo for the message, then back to the original gobo for the remainder of the service.  It's basically the same on all the 3-4 different sets of cues.  Problem is, the gobos weren't there (gobo wheel was set at 'open') for the before and after message on all of the sets, but the message gobo's were still there.  Edge was out of focus on everything as well, but they're set at focus and out-of-focus depending on cue.  In addition, I have 11 color scrollers, and about 8 or 9 of the 11- when I choose their channel, if the color is on F16 and I move it just one notch to go to F15, it goes to F1.  If I move it back one notch to go to F2, it goes to F16.  However there are 2 or 3 that do allow me access to all the frames.  Everything was fine on 1.4.5, I upgraded yesterday, then first thing today it's a mess.  Then to top it off, I reprogrammed one of my sets, failed to save (DANGIT!), shutdown, then restarted and what I had changed in the one set had reverted back to open on all the gobos, even though the console's supposed to start back up like it was when it was shut down.  HELP!!!!  I may have to go back to 1.4.5 and see if it goes back to the way it was.
