Has anyone had any success in running the OSX offline editor with x-keys? I downloaded the macro files from ETC but cant seem to find a way to upload them to the x-keys pro.
I'm pretty sure that in order to set the x-keys pro to the proper mode for use with EOS/ION you need Windows (I use Parallels personally) and Macro Recorder from x-keys.com
Thanks for the suggestion.
Once you upload the macros do you continue to use it in Windows or do you switch.
You won't need Windows once you upload the file to the x-keys.
You'll want to set the x-keys to Memory Resident Mode, in that mode the configuration is stored in the x-keys itself and should show up on in Mac OS as a standard USB keyboard.
