Anyone using ArKaos VJ 3.6.1?
I am trying to use Ion with my copy of DMX VJ and I am having a problem with the Flash animations.
Has anyone figured out a way to access more than the first two flash animations?  With the "File Type" encoder set to "Text" the only options that I have with "File 1" encoder are Layer 0, Camera 1, and Camera 2.  It's obvious that the profile has an error in it, and the "File 1" encoder only has the options for the "Video" setting of "File Type" rather than the 255 options that I should have with "Text."
Any work arounds?  I thought it might be as easy as editing a wheel, but there are no edit options for any wheels under "attributes" at all.
Thanks for any help!
  • I use Arkaos fairly regularly.
    Although never with ETC consoles.  By all rights, if you can access the first two flash animations you should be able to see all the rest too.  Have you changed any of the animations?  Make sure they are named properly.  I know this is the ETC forums, but with Arkaos you are really better off using a console that actually speaks the MSEX protocol so you can get your thumbnails.  MSEX 2 is coming soon which should REALLY help things with media servers in general.  (Chamsys is your friend)
    'D'
  • Thanks for the input.  We just commited to a brand new Ion system, so getting a console that speaks MSEX is not going to be an option (unless that is a planned upgrade for Ion).
    The problem with accessing the Flash Texts is an issue with the supplied profile for ArKaos.  I was able to bypass the problem by writing my own profile, but it is missing the feature lists and other descriptors.  I am told that ETC is looking into the problem.
    Regards,
