Selador Vivid/Paletta+ION colorfade question
Hello,
I have a rig with some Selador Vivid11s and Paletta 72s controlled by an Ion, 1.7, tracking. What we are doing:
Select a unit, @full, pick color in color picker. Record cue 1. Select same unit, pick new color. Record cue 2.
The desk, when running the cue, rather than fading up the LEDs required and fading down the LEDs not required, fades from one hue/sat to another hue/sat on the color wheel (So, with ML controls open and the unit selected, the dot travels around the circle of the color picker rather than across it). This gives some strange in-between colors sometimes and sometimes makes smooth crossfades between colors turn into abrupt changes. Is it possible to force the cue to record hard values for the 7 LED levels in each cue and fade between those rather than recording only the hue/sat and fading "around" the color wheel?
Stevan
