Is there a way to disable the REM/DIM function on the ION console? It gets awkward (and dark) on set when that button gets pressed by mistake.
MWeeks
MWeeks
can you provide more information?
what's they syntax you're using? what exactly happens with dimmers, what exactly happens with fixtures?
now it’s ok...Ihad to set up the GM Exempt on patch...thanks a lot anyway!
