Flexi-Active Channels prevents thru selection
Firstly, apologies for the cryptic title - it's the best I could come up with half way through the second production week on the trot!
We've noticed that when using the "Active Channels" flexi mode, non-active channels are not selected when using 'thru'.
For example: if you put the console into the flexi display mode, "51+53 @ <FULL>", "51 <THRU> 53 @ 50" - you get 51 & 53 @ 50, but not 52.
I can understand wanting this function from time to time - but would have thought you'd use the syntax "51 <THRU> 53 <SELECT ACTIVE> @ 50".
So....is this intentional behaviour? or is it a bug coming from the Next-follows-flexi fix?
Cheers,
Dave
