Is it possible and how to install external touch schreens LG L1730SF on ION ?
Dario
Dario
After a quick read of the manual off of LG's website, that monitor is not one of the supported touchscreens because it does not use one of the installed drivers on the Ion. The Ion supports touchscreens that either use the ELO driver or are supplied by ETC.
Are you sure,
because I already bought that model. Which
models support etc?
Thanks to the technical support.
Best regards,
Dario
Dario, you can find the details on which touchscreens are supported in our wiki article on touchscreen support: http://community.etcconnect.com/wikis/products/knowledgebase-external-touch-screens-for-eos-ion-congo-congo-jr.aspx
If you have a touchscreen that is not supported by the Ion console, there is a good chance that you will still be able to use it on a Windows Client PC...any drivers that are needed can be installed on this PC, and you can use the free Client Dongle that you receive when you register the desk to connect it to your Ion.
Fortunately, the requirements for a Client aren't very high, so there is a good chance that you will be able to find a very affordable solution.
Let us know if you have any problems, Dario-
-luke-
thank you , Luke
