1.8 bug
so i did the first show with the update and the board had a oops moment. i wanted to copy a cue. pressed coppy cue and got a syntax eror and the line read cue 20 which was the cue i was sitting in, not the one i wanted to copy. i "saved as" and was not able to enter a show name, it saved with the current name. also could not use " go to cue" that gave me a syntax eror also. i have the show file, first one to respond gets it.
after the show i exited the shell and re-entered it and the go to cue, and cue worked. i went to lamp off the rig and was not given a chance to confirm the comand, it bounced past that and doused the rig.
