Is there a way to only save the parameters of my choice in the PRESET applying this on all channels, Like a filter.
ex: a preset with pan , tilt , shutter , zoom but without intensity and color
You actually want to use the filter function. If your on Eos then in the middle of the two touchscreens you have a filter button. Push and hold this button and select the NP tiles (Non-Intensity Parameters) that you want to record. You should notice that what you dont select turns gray and has a small "N" in them-meaning Null. Now you can record your preset and it will only record the selected NP's.
On Ion there is no Filter hard button, instead look on your external monitor at the CIA and notice the Filters button on the screen. Push this button once and now you can select the NP's that you would like to record.
Another way to achieve this is with selective recording. Select your channels, then select your parameters then record to a preset. So your command line would look something like this. [Select Manual] [Focus] [Form] [Record] [Preset 1] [Enter]
