Radiance Hazer on a Submaster
I have my hazer on subs, one sub for the blower and one sub for the haze output. I made the subs exclusive, but when I use record they still record into the cue. Are non-intensity parameters on a sub not  able to be exclusive?
Using [Record Only] does keep them from being recorded, but I'm just curious why the sub is exclusive and they are still recording into cues. Thanks.
  • I didn't have this problem setting the subs to be Additive/Proportional/HTP/Exclusive in v1.8 and with the Home Preset set at default.
  • Well it seems to be functioning correctly now. I could swear that earlier today it was recording the levels from the subs when I used [record]. I'll have to keep an eye on it.
  • Your not crazy I had the sam exact issue when I programed my last show on version 1.7
  • I figured out what the issue was.  I had initially started to cue the hazer into the show.  I then took it out so I could run it manually.  In blind spreadsheet I noticed in one cue there was a blue 0 shown for the hazer channel (maybe I accidentally cued an intensity level for the channel at one point).  Also all the cues after that showed a purple dash (-) where the intensity is shown.  I'm not exactly sure what the dash indicates, but it looks like it is there for all channels that have been cued in the show.
    I got rid of the 0 by doing ch@[enter] and made sure the channel was clear for the rest of the show. After this the rest of the cues I recorded using the [record] key recorded as they should and did not include the hazer which was being run form submasters.
    [edited by: bosox242 at 7:44 PM (GMT -6) on Sun, Nov 1 2009]
