Here goes,....
Let's try to explain the behavior we are experiencing.
We set several FADERS, as a Intensity Master, with CUES loaded on that. Ex. 10/1 on 1 st , 11/1 on 2nd and then on. We have experiencing the following either with Moving Lights as with catalyst as well.
Setting the FADERS as Intensity Master, we expect to they "Prepare the Cue parameters" ( except Intensity ) for us, on GO ( Flash button ), then I have the Intensity of the Cue on my hands.
Most of the times, that behavior is correct. And so far perfect.
But sometimes, ith all faders down, I press GO ( Flash Button ) and the parameters changed in live,... you can see the Moving lights moving, or the catalyst preparing the Cue... Is like the Master intensity was not there..., SET TO 0 % , is like pressing GO with the Master at Full.
If I GRAB the Intensity Master up and Down, he picks and Zero the fades.
Or the GrandMaster also acts OK.
But the strange is that happens only sometimes aleatory, is not onl the same cue.
Any Clues ? i tryied HTP / LTP / independent / etc....
Thanks for the help
Marina
