I tried using WYS and EOS Offline at the same machine, and It work fine.
But when I try to use 2 machine to share the workload, I can't connect the WYS to the EOS offline.
Is there's any special method to set it?
Thanks.
Thanks.
Andrew
I assume you were connecting this via a network cable. Please check the following. Booth machines have a static IP or at least one of the machines is a DHCP server. Make sure that the IP ranges fall inside a = subnet mask. Make sure they are connected to a switch. If they are not you will need to use a cat5 cable called a crossover cable.
Hope that helps
P-
2 Computer was in the same Network and connecting via Router (Wired)
And both was in the same subnet already. But still the WYS didn't show up the computer that I run the EOS Offline.
I didn't have any firewall with the 2 computer, or is there any Firewall setting I should beware of in the Router?
Andrew
My next question would be, how is WYS translating the data. If the computers correctly then there is probably something on the WYS end that is preventing this from happening.
P-
