How I Program 6K Spacelights (and other multi-intensity fixtures)
With the introduction of software 1.8, a new manufacturer’s folder has been created in patch called “Movie Fixtures.”  In this, there are some of the most common fixtures you’ll find on movie and tv sets.  What’s great about these fixtures is that you not only have access to all the individual intensities- but the console will create a virtual master intensity for each fixture.  This means that if you set three globes in a spacelight at full and the gaffer says, “Take them to 80%” all you have to do is set the channel level at 80%.  The three globes that were at full will now be at 80%.
Once you’ve patched the fixtures, your channel view in table mode will show you the channel level, plus the individual intensities (Intensity 1, Intensity 2, etc.).  The intensity wheel will control the master intensity for that channel; the encoders will set the individual intensities.  To access the encoders for these channels, simply hit the [custom] button next to the other parameter categories.  When you see the individual intensities on encoders, you can hold them down on Ion to get your {home}, {min}, and {max} options across your soft keys.
Once I’ve patched my 6k spacelight (for example), I make intensity palettes for how many globes I want on in each spacelight.  I filter these intensity palettes to just include the individual intensities and not the master intensity, this way I can change the number of globes I have on without changing the overall intensity.  To do this I do the following:
1.)    In CIA, I hit ‘filter’ then choose ‘Intensity 1,’ ‘Intensity 2,’ ‘Intensity 3,’ ‘Intensity 4,’ ‘Intensity 5,’ and ‘Intensity 6.’
2.)    I then select all of my 6k spacelight channels.
3.)    I hit the softkey {make man} then [enter].  This makes their values manual- which means they’ll turn red.
4.)    I record Intensity Palette 6 and label it ‘6G’ for 6 globes.  The 6k spacelights default their home position to all individual intensities on at full.
5.)    I select all my 6k spacelight channels again ([select last] works well here), then set ‘Intensity 1’ to zero.
6.)    I record Intensity Palette 5 and label it ‘5G’ for 5 globes.
7.)    Repeat step 5, but set ‘Intensity 2’ at zero.  I, of course, leave ‘Intensity 1’ at zero.
8.)    Repeat step 6, but with Intensity Palette 4 and a label of ‘4G.’
9.)    I repeat steps 5 thru 6 until I have Intensity Palettes 1 thru 6 recorded.  I can now grab any spacelights at any time and tell it how many globes I want on instantly!
10.) Remember to clear your filters once you’re done!
Once I’ve recorded my intensity palettes, programming 6k spacelights is very fast.  If the gaffer says “Turn on 4 globes in spacelights 1 thru 10” all I have to do it grab those channels, double tap [@]- the quick command to make them full- then type [intensity palette][4][enter].  If the gaffer then says “Now put them at 60%” all I have to do, since my channels are selected, is type [@][6][enter] to put all the globes that are on at 60%.  And if the gaffer then says “Let’s see that with 5 globes” all I have to do is type [Intensity Palette][5][enter].
Please feel free to add any suggestions that you might have to this post.  I know there are many of you who have great ways of programming multi-intensity fixtures on sets!
  • Excellent, thanks David!
    This has already been a huge help on our set.
    -Tom
  • I see that this was posted in 2009. Is this tutorial still current in 2017? I'm about to start a show using the Ion (my first time programming on the Ion, I used to program Expression 3). We will be using 6k space lights, and I'd like to be confident that these rules from 2009 still apply.
    If not, where can I find the updated procedure?
    Many thanks!
  • Rather than select all spacelight channels, select one and press {by type} in between the IP number and the label. This is quicker and easier than selecting all spacelight channels and also means that any spacelights you add later will automatically get your IP.
    Double-tapping [at] sets intensity to a user-defined level, not necessarily full.
    "If the gaffer says “Turn on 4 globes in spacelights 1 thru 10” all I have to do it grab those channels, double tap [@]- the quick command to make them full- then type [intensity palette][4][enter]. "
    It's faster and easier to have the master intensity recorded at full in all 6 IP. If the gaffer says “Turn on 4 globes in spacelights 1 thru 10” all you have to do is grab those channels, and use your magic sheet object or direct select for IP 4. If he's controlling intensity by turning globes on and off, he wants the globes at full. Regardless, I have 6 IP (61-66) to control globes on/off, with master intensity at full, and 11 more IP (1-11) to set master intensity only.
  • Thanks for the reply.
    John, I don't see {By Type} anywhere.
    I'm encountering some strange problems in trying to set up these IPs. Could be because things are different in the software version I'm using as opposed to the version which was current when this post was originally shared in 2009.
    In applying the newly created IP to my Space Lights, some of them came up as programmed: IP 1 brought up 1 globe, IP 2 brought up 2 globes, and so on... But when applied to other Space Lights, the master would default to 100%, which I did not program to do. On my show, the gaffer likes to call out how many globes and then to slowly roll them up on the master to his preferred level.
    I went into [undo] and deleted my work 4 times, only to reprogram, to no avail. Same issues would arise every time. I could have sworn that I followed the instructions explicitly.
    No big deal, ultimately. I'll continue to manually bring up the Space Lights as I had been prior to trying the programming discussed in this thread.
    In the meantime, I'm scratching my head wondering what went (or what I did) wrong....
  • Did you record all of your 6k fixtures in the IP or just the one? I could be wrong but I understand that if you use the {by type} if you add other fixtures of the same type later it will automatically add them to the IP
    The {by type} button is softkey 1 (SK1) and it came up when I did [record][ IP]
    Hope this helps.
    Regards
    Geoff
  • Geoff,
    Thanks for the reply. I recorded the IPs both ways: By using just one fixture, and also recording all of them.
    I'll check the {by type} softkey again when I get behind the console after the holiday break.
  • Geoff, you're not wrong.
    Anthony, that 100% master intensity has to be coming from somewhere. As you are recording your IP, check in Blind Spreadsheet. (It's very helpful to have another machine on the network for this purpose.)
    [Blind] [Int Palette] and [Format] until you see the spreadsheet.
    What you want is this:
    The first channel has all its data in blue. The rest of them have their data in magenta.
    The master intensity is 0 for every channel and palette. The sub-intensities are all 0 or 100 depending on which palette. There should be no blank cells for any of the channels.
    You can also create and edit your IP from this display but of course if you do that you won't learn what you were doing wrong.
  • Thanks John for confirming. I am new to this game and am learning lots from various forums.
    Regards
    Geoff
  • As a side note, there's no point in using the filters if you are recording all seven intensity parameters into your palette.
