On the current show, I have a row of 5 ColorBlazes all set to the highest resolution, resulting in 60 controllable LED channels in a linear array.
I have created a "rainbow" of color palettes (ROYGBIV), then created an absolute effect with these palettes to create a moving rainbow across the entire groundrow using the standard grouping setting "spread." Now, to create a more segmented rainbow (ie one where there are multiple rainbows moving across) I copied the effect and changed the "Grouping" to 12. I left both effects "Entries" as "Cascade and Fade by Size" and the "Exits" as "Fade by Size."
Now when I put these into two different cues back to back and run the transition, the first effect immediately bumps out and the new effect stutters in. Ideally I would like this to be a smooth crossfade. Am I doing something wrong? Or should I try this effect in a different way? I have played with the "Entry" and "Exit" on the effects with no real luck.
-Nick
