Does anyone know why when I set the Default cue timings in the setting to 3 second it still records them in 5!
That sounds strange - never heard of that. Is this after starting a new show or opening another one by any chance?
-luke-
both mainly a new show we also import shows from Ion offline where we have pre plotted empty cues
Ah, that would explain it. As the default cue times are a SHOW setting, this will be lost every time you start a new show, and the default time is saved with existing showfiles as well.
Opening shows that were written in Offline will be the same - empty cues will have the time that was the default when they were created - it is not dynamic. You can change ranges as required, however. For example [Cue] [4] [Thru] [8] [Time] [3] [Enter].
-luke-
