Trying to setup Ion Onpc with Visualizer (need Help)
Hello, Im trying to make the Ion Onpc work with the capture Visualizer. So far ive downloaded everything including the ETC Net3 gateway configurator and the capture visualizer picks it up but i need to figure out how to get the ion to connect to the Net3 gateway configuator ,thanks
  • You do not need any other software to connect Ion Offline to Capture or any other network-connected Visualisation package that supports sACN, ETCNet2 or ArtNet.
    All you require is Eos/Ion Offline.
    The Net3 Gateway Configuration Editor is for changing the configuration of ETC Net3 Gateways and network-connected Radio Focus Remote base stations, and has nothing to do with visualisation in any form. If you don't have those pieces of hardware, you don't need GCE.
