I'm starting to lose the will to live trying to work out what I'm doing wrong... I have checked the manual and searched this forum for further info. So giving up and pleading for someone to help!!
I have SFX running on a PC which is outputting SMTPE EBU (25) via a MIDISport 2x2 to the MIDI input on my Ion. I'm pretty confident this is all hook up correctly as I can see traffic on the MIDISports led on the correct output.
I have Enabled SMPTE Time code receive in setup/show/showcontrol.
Then I go to the show controls display and set list one to-
Type-SMPTE
Source- 1 (What does this relate to???)
Internal- Off
External-On
First Frame- 00:00:00:00
Last Frame- 23:59:59:59
FPS-25
When I run the clock in SFX nothing happens. The Ion shows- 00:00:00:00 Clock Disabled. The Status display is always in grey an never changes.
Am I doing something wrong? Are there any other settings I've some how missed?
I'm on an Ion running v1.8Patch0.0GA Build27
Any help would be great!
