Hi there! I'm working with the ION offline editor on Mac OS X for the first time. I'd like to record groups in the group screen like I usually do on the ION, but when I hit [group group], nothing happens. Am I missing something?
[G] [G] works perfectly for me.. are you double hitting fast enough?
Offline I find using the Record Targets Lists in the Browser helpful.
As fast as I do on the ION. Doing it as fast as possible doesn't seem to help.
This might be a silly question but do Macs have a scroll lock button?
If so make sure it's pressed.
Cheers
Richard
Make sure you are running the latest version of the OLE. I believe the double-tap target issue was fixed in a relatively recent version.
-Josh
The double hit record target function in offline was added in 1.7. Before that build, you need to access the group list from the browser/record target lists.
No, Macs do not have a scroll lock button.
Just a heads up to you guys. In 1.9, we are removing the "scroll lock engage" requirement for PCs. When that software is released, the alpha numeric keyboard, when attached to the offline software, will default to Hot Keys mapping. If you want to use it as a regular keyboard, the Scroll Lock on will do that.
a
