Hello I'm looking for a fonction that recall only the manual values from a channel to another.
thanks.
Clément
thanks.
Clément
Try chan xx thru yy (Insert filterd value here such as intensity, focus, beam or colour) copy to chan zz
If you select the manual data in your filter it will copy it across.
Let me know if this works for you.
Hello thanks for the replie. It really takes to much time select filtering (if i want to makes beam palettes only for zoom for example).
to populate my colors palettes i can make a macro that recalls all my fixtures from one simple RGB and save the palette.
To populate a beam palette only for zoom i can't !
Filtering is found in the CIA when you have selected the fixtures and is one screen touch or mouse click. Another option is use the record only instead of record. Record only will record only the manual data and if you already have data in the target it will add to the data and not overwrite it.
There are videos on you tube that cover filtering.
Let me know how you get on.
Geoff
Filters also can be recorded into Snapshots.
I made some dedicated Snapshots for regular used Filters.
Quite handy.
