Maybe im overlooking something obvious but i cant find this ribbon over the encoders on my Gio anymore. I see them in Nomad as a client, but not on the console. Any suggestions would be most welcome.
Hi Ole,
What version of Eos are you running? If you save your showfile, restart does the lack of ribbon persist? After that if you go into the Shell > Maintenance > Deep Clear, restart Eos, patch a multi-parameter fixture, select it in live - does it appear?
Dear Ole,
are you seeing the commandline, the Triangle and Lock(on the Right)?
Im running Eos 3.1.5. I have tried all of your suggestions, but it is still missing
Yes i see them
Will you please save logs and send them in for us to review? Please reference this Forum Post.
I'm not running a Gio but in Eos there is an option to "Force Hide Encoder Ribbon". Go to Setup > Device > Displays and make sure "Force Hide Encoder Ribbon" is disabled.
What a Feature... Wow.
Never knew about it. But looking good, for that case.
