Is it possible to move Items/Icons you have created or edited between magic sheets?
Or is there some way of storing said items, so they can be used on any future sheets?
Many thanks
Phil.
Many thanks
Phil.
copy/cut/paste works between magic sheets. in edit mode you can use Ctrl-C/X/V on an external keyboard. Eos will renumber objects during this move. to avoid this group (Ctrl-G) the objects first (even if it's just a single one), then do Ctrl-C/X/V, and afterwards ungroup again.
I used this today. It was like magic. Glad I read this response.
Geoff
It was like magic.
Thats why it is call Magic Sheet ; )
Good to read that it worked all out for you.
Thank You, it works but a little basic....It would be better if you could store your own library of tools.
