iPhone iRFR
Is there a way to do a dimmer check (or address check) with the iRFR? I've written a macro but was wondering if it's possible without. I see that there is an option for it under Park and Patch but there's no easy way to step through dimmers.
-Danny
  • The iRFR operates the same way that the handheld RFR unit does. This includes the same syntax.
    From page 329 of the Ion manual:
    Park Mode
    This mode is used for parking channels and also for “channel check” and “address check” functions.
    {Address} and {Channel} are used to select addresses or channels for parking.
    • <Channel> [7] [@] [5] [Enter] - Parks channel 7 at 50%.
    • {Address} [8] {Full} - Parks address 8 at full.
    {Full} and {Out} are used to set those levels for channels or addresses. {Out} parks the channel or
    address at 0.
    {Next} and {Last} are used for the check functions (see below).
    • [9] [@] [Enter] - unparks channel 8.
    Channel or Address Check
    When a single address or channel is selected, using {Next} and {Last} you can rapidly increment or decrement through the channels or addresses to verify function. This only works when a single channel or address is selected on the RFR and then {Next} and {Last} is used.
    In this mode, the right thumbwheel will function as next and last commands, and the left will function as the level wheel.
    Also, sorry that I wasn't able to respond faster on ControlBooth.com.
  • Awesome! I will try this out later today. Thanks!
    and lol it's ok. Gave me an excuse to figure out what my password for this forum is...
