I have a scene with an electric chair that turns on and off multiple times and I would like to follow the actor on a submaster. Is it possible to change the ColorSource Spot and Pars to strobe on and off with a submaster while in a cue? I'm needing to follow the duration and number of times the actor throws the switch which is not always the same. Console is the Ion Xe 20.
