I am wondering if there is a solution to trace values in blind with the lighting desk and eos version in title ?
Could be useful sometimes when Correcting/cleaning cuelists.
Kind regards
Jano
Kind regards
Jano
While in Blind Cue X: Channel 1 at 40 Trace Enter
Thanks It works well with intensities, does it make sens to do it with FCB Parameter to you ?
If yes how would you do it ?
It will work from the command line similar to intensity.
Chan 1 Red 34 Trace Enter
There is not a way to use the Encoders or ML Controls and Trace in Blind.
Great Thanks, I didn't understand that it was mandatory to specify the parameter values I wanted to trace.
