Hello, I'm in cue only mode. I want to remove channel 1 from cue 1/58. I go to blind, type 1 @ enter. The channel doesn't get removed from the cue, instead it goes to FL.
How do I fix this? Thanks
This is not a question of cue only. The reason you're seeing this is that At Enter removes move instructions, but as soon as those are gone the channel will stay as it was in the cue before.
What are you trying to achieve? Are you in a multi cuelist situation?
Yes I am in a multi cue list situation. I'm trying to remove channel 1 from a cue so it is not in two different cue lists that are both running simultaneously. :)
I found the answer in the manual, use {Make Null} in Blind on parameters you don't want to playback.
Is there any way to remove them though? Just for the sake of my brain not wanting to see them there.
The most thorough thing you can do is releasing those parameters in a cue. There will still be values, but they're greyed out and Eos hands control over to the next control source in the line of succession. That way you don't have to steal the parameters from another playback.
Does this help?
