how to setup a fader to go as soon as you bring it up and release when you bring it down? having a cue list in it and or a regular sub with moving light info.
For a regular "Sub with Moving Light Infos" you can make the Submaster an Intenity-Master (Int-Master) and set the "Unmark 0" to On.
This can be done eigther in Tab36 or in Blind->Submaster (Tab15 or hit [Sub][Sub])
For the Cuelist i have to pass. I know that this is a Hog4-like feature (as well as the feature before).
But EOS is a little bit different ; )
thank you, I will give it a try. added question, when you bring the fader down can it release in time? if so, how would you set that up? and can different faders have different release times?
Also, if someone else could help me to do the same but using cuelist it would be be really helpful.
thnaks
As far as i know and tested, there is no manual Release-Time on Subs with that method.
Release time is always in 0Time.
I-Master subs use their Up and Down times (which you can find in the sub's properties) to mark and unmark. The Down time would be what you referred to as release time.
This is not currently possible for cuelists. If you still think this would make a valuable addition to the Eos software, please head over to the Feature Request section of this forum and add a post there.
Thank you.
