I am fairly new to magic sheets, and have completed one with group buttons.
I would like to add a button or a macro with clear-sneak-enter and was wondering what the best way to do this would be?
the two options that come to mind would be either a macro or a command object.
if you make a macro (easiest would be to learn it) then have a magic sheet object that is set to type Macro and its number.
or you add an object to your magic sheet you can change it to type Command and then in the command box you enter Clear Sneak Enter
I did the command option and it worked like a charm.
Thank you for this info!
