Nomad - how to enter {pan} during offset (L3 Build Palettes lesson)
The instructions on page 25 of the L3 workbook are to enter this:
[Select Last] {Offset} {Chan Per Group} [2] {Pan} [Fan] {Center} [Enter]
On the board in the video he is tapping the encoder to input the {Pan}, but after I use Offset - Chan Per Group - I can't find any way in Nomad to input the {Pan}. I have no encoders, and in the other lessons I would use the CIA area to find Focus - Pan and tap the title to insert it. Not available here.  If I click on the Focus box in the bottom row it adds Focus to the command line and then when I try to tap Pan in the CIA I get "Error: Parameter already specified".  I have OSCRFR running, but tapping on the center of the encoder wheels there does not send anything in it just moves the encoders. I can't find any keystroke shortcut documented to do this, so what is the magic trick?
