Hello,
1. if i edit an Effects in Live with the Effect-Display and want to reset Rate or Size:
[Effect] 904 {Rate} [Home]
I will get a Error immediately in the Command Line.
Hitting [Enter] still do the as expected, and that is ok with me. But the Error should not be placed.
And the Parameter still is Manual Data (see also 2.)
2. If i edit an Effect in Live with the Effect-Display and want to reset Rate or Size:
[Effect] 904 {Rate} [Sneak] [Enter]
The selected Parameter sneaks back to its Homevalue, but remains Manual Data (displayed Red) while unchanged Parameters are diplayed in Magenta.
In my oppinion [Sneak] should make the Parameter Magenta again.
EOS v3.1.x
