My RPU backstage isn't connecting with the Master Console, ETC Gio in the booth.
They are connected through ETCNet, and had previously communicated. What am I missing?
Thank you.
Thank you.
- can you ping in both directions
- in the shell > setup > network is Multiconsole activated for both, and on the correct network port
- are they on the same exact software version
- are they on the same exact fixture library version
- are they set to the same language
Do you still require assistance or were you able to figure it out?
