Hello,
I try to test simple 10 channel with the channel test and it doesn't work correctly in the last version.
When i take 10 channels (simple dimmer) i make: 1 thru 10 @ Full test chann (softkey) enter. When i use next and last they stay only on the first and the second channel.
I make the same thing with highlight preset and it doesn't work when i write 1 thru 10. The first channel is just selected.
To be sure i try with the 3.1.4 version and it work correctly !
Tell me if you see the same thing. I'm on a nomad version with a cmd key !
