I am using a Martin JEM ZR25 smoke machine with the 1ch profile. I tried to put it on an Inhibitive sub, but when the inhibitive is used it drops the fog output to 13 which isn't actually 0 but just the beginning of the smoke output. In the profile there are 3 ranges and the inhibitive only seems to run in the 2nd range.
Anyway to change that?
Ended up just changing the profile over to a dimmer. and then the inhibitive works just fine.
