Hello,
I am patching in a chauvet geyser P7, its address has been set properly and patched in. However, it is not responding to any commands from the board. Does anyone know why this might be? Than you
Hello,
Dmx confirmed at the head with tester or another light? Sometimes profiles are wrong from default fixtures library. Check to confirm the intensity addresses are correct. Do you know how to edit a fixture on eos?
Just checking if you did find an answer to this. Please let us know, thank you.
Yes, Thank you for following up. The problem, as I suspected, was user error. The problem was identified and solved. Thank you
