How do I set up latchlock for power to movers?
You mean, you have a Switch with power for your Moving Lights and you like to have the Switch always under controll?
I would patch the Switch-Channels as a Non-Dim and park them at full.
Its has more control then what a non dim does, I've seen it done before, thought I could remember how but turns out I can't!
If there are still questions related to this please let us know, thank you.
Hi Bernie, I have a Nomad system dedicated to running LatchLock channels. I use a cuelist that will in cue 1 set the addresses to the specified Latch On level for the specified time by then having a follow cue 2 set them to 0. And the same process for Latch On, just with a different value to Latch them Off and different cues.
This could be done on your Eos console if you don't mind the additional cue list required. You could also do this with a macro, utilising wait times.
