How do you view a timing of a cue while its running?
You mean while the times are counting down you want to see the cue time? Two things you can do:
In the tab settings of your PSD there's an option if you want to see all categories counting down or if your want them to always show cue times and only have Duration counting down.
The other one depends a bit on the model of the console. Some consoles (Ti, Gio, @5, Apex) have a second time button. Not the one next to Shift and Delay, but rather on the right hand side next to Flexi and Format. As long as you keep this pressed you will see the original times. On consoles that don't have this extra Time button you can use the combination About+Time.
Oh perfect thanks so much.
