Hi, I have a question about the time inof a submaster. I set the entry time but when I raise the fader to 100% it doesn't respect this time and when I press the bump button I have to hold it down to make it fade in.
the time affects only the bump button, not the fader. that's expected behavior.
if you want the sub to stay on after the fade in, but you only have to press it once, you have to set the Dwell Time to Hold.
