Hi!
I'm trying to find a way to operate 16 bit dmx fixtures in "ultra fine" steps.
When for example using a 16B dimmer, the lighting desk combines 2 dmx dresses to make the 16b bit value.
When operating the fixtures the normal step's on the level wheel on an Element desk are 101 steps ( 0 to 100 %)
If I use the Data latched command I can dim in 256 steps (8bit dmx value 0 to 255 )
With te command ch @//value I can set a value in the fine way that I soo please ( 16 bit dmx value between 0 and 65.535) but this would mean typing in every value one by one and checking if that works.
When for instance working on low levels the final 255 steps (in a 16 bit value) can make a huge differences in what you see on stage when using LED and I would like to easily scroll trough them. (Lets not go in to dimming curves)
I really hope there is a secret key combination like holding down shift when using the level wheel to unlock the 16 steps and have the pleasure of the ultra high 65535 resolution instead of 101!
I can't wait for your ideas.
