Hi All,
I'm having issues with selecting a specific tab from within a macro if the target tab has a decimal point. For example, I can change to Tab 3, but not Tab 3.3. Adding the decimal point just makes the macro appear to tab across to the next tab, not the specified tab.
After looking through the forums, I have also tried the "Tab 3.3" syntax and "Tab_down 3.3 Tab_up" syntax on a command button, but neither seem to work.
I noticed that the OSC commands list "SHEET" as the internal EOS command for the Tab key, but this doesn't seem to work either.
Is this a bug, or do I need to do this some other way?
I am currently running EOS version 3.2.0.291 on an Ion XE
Chris
