Hi
when i want to set a color parameter to 0 with "at out", it always goes to 100%.
Is this intentional? I had expected something else.
Dirk
Hi
Dirk
Either the default value in the fixture profile for that color parameter is set to 100% which is common for colors to be defaulted to on full, or the home preset has those parameters set to 100%. Check both.
in the fixture profile the parameter is set to 100%.
so "at out" is the same as home
Hi Dirk,
if you want the color parameter to go to 0% at out, then you can change the default value of the parameter in the fixture profile to 0%.
Please be aware the difficulty that this setting sometimes brings with it, is that when you bring the fixture intensity initially to 100%, the fixture will not output light because the single color parameters are still at 0%.
Hi Corey
for me it is okay like it is.
I'm training a new operator and she is typing red at out.
we both thought it should go to zero.
now i know why and it's okay
