Hello, Ch X Pst Y Sneak Time 10 doesn't take the time, Ch X Pst Y Time 10 doesn't neither. Can't find how to bring softly a pst in live,what is the way?
Chan 1 Preset 5 Sneak Time 10 Enter is the correct syntax and does work. the syntax without Time does something else.
the only situation when this wouldn't work is if the parameters within the preset are Snap parameters (like e.g. Color_Select or Gobo_Select).
thanks, got a doubt. then another bug with our ion xe v3.2.2
"Chan 1 Preset 5 Sneak Time 10 Enter" , that's what i used, didn't take time, went straight to the preset (tried more than one time)
did you type Preset 5 or did you click a Direct Select button?
i did type preset 5
did you see this on stage? if i type ch X pr y sneak time 10, the preset on the monitor changed immediately, but on stage it changed in time.
Did you have Highlight enabled?
thanks for your time.
Dirk Gnebner the preset changed immediatly, but but you could still see datas go on time. In my place, fixtures take focus straight on stage and on monitors, absolute values speaking
Wuz314159 .highlight was disabled every time
Not realy helping with the Syntax, but how about using a Manual Time Fader?
that's something i use during rehersals, just to be discrete while working. It has to be absolutely flexible, like a home or a snap function, not fixed.
isn't a Time Fader not the maximum in flexibility?
Or do i missread your answer?
you haven't misread, i'm just not used to use faders this way. Not sure it would replace pst sneak time, but always good to learn something. Could you explain? i design a fader to be a time fader, and ,every time i load inside the pst i want to bring softly?
as i don't know the process, seems quite more fastidious than say ch X pst X sneak time 10
You can set up this fader one time and keep using it. If the fader is at the bottom all the commands that result in red stuff will happen fast, if you have the fader at the top, it will happen slow.
So set it up, go to Fader Config (tab 36), choose an empty fader and choose the type Man Fader.
But even with the manual time fader, I still would like to know why it the regular syntax doesn't work...
What parameters do you have in your preset? Do you trigger the preset from direct selects or do you type in the command line?
but one thing i don't get: this fader is dedicated to a pst? chs? nothing, just an empty man fader you fullfill when needed?
