I just updadted our Element 2 to ver 3.2.2.25. Our Lighahck box we use for encoders now, will not connect! The display says: "Waiting . . .".
I check OSC Send and Recieve were ON in Settings.
Is OSC over USB activated, you find it in Setup>Device Setting>Show Control>OSC
Yes they are both enabled. I am getting very nervous. Usually I get replies very quickly to my questions but this one seems ot have caught folks off guard. If I cant get it resolved then I will have to find a way to go back a version which I bleive can be very tricky.
Did you looked there
Ill have to admit to stupididity here. A USB break out box was plugged into the console and the LIghthack into that. . I removed it and went direct and things worked. Sorry about this. Its all a learning curve.. Thank you for your help.
