hello, is there a simple command to just quit setup in a macro? i made some workaround, just would like to know if that's possible straight.
indeed, but i don't want to go live, i want to stay blind. I noticed [live] is efficient to go out setup, but [Blind] is not.
How about [Displays]? Or a macro that hits displays twice to also close the CIA?
I tried already, didn't work. By the way, using display doesn't exactly close setup.
I open setup, hit DISPLAY twice, CIA closes. But then when i hit any touch, setup appears again.
The "cleanest" way i found (to remain on the exact display i was before my macro) for now: start the macro recording a snapshot, and recall it at the end of the macro.
But i saw this morning that hit BLIND, outside a macro, is working to exit setup so i just have to find out why it didn't work when in my macro.
What is the over all purpose you are trying to achieve?
Because you do not need to enter Setup to enable/disable things via Macro.
trying to macro " preserve blind cue enable" and "...disable". You might be right, hadn't thought of trying in macro without opening setup, and simplest is always the best. i'll try.
You were right, in my macro, no need to open setup,preserve blind cue enable / disable works perfect. Thanks!
For some settings you have to be in setup. I can't adjust the sneak time from live, but I can adjust the manual times from live.
adjusting the Sneak-Time is not macro-able.
A few years ago someone surgested a work-around via different users. because Sneaktime is a user-based setting.
On the other hand you always can use a dedicated sneak-time-Macro.
All of them are work-arounds. But nothings beats old handwork ; )
PS: if you use [alt]+[S] on you Keyboard you are much faster in Setup
