This is a similar issue to CSV import/export of cues has inconsistent time data
When I record a sub bump in timecode it is recorded as 'Sub 1 On' 'Sub 1 Off'. 2 separate events in the Timecode.
When I export this it is written only as "Sub 1" "Sub 1". It looses the on/off label.
When I re-import this it imports both as "Sub 1 Bump".
This renders importing & exporting Timecode sub bumps effectively useless if you are trying to move between consoles or environments or such. Fortunately my workflow isn't impacted by this as I only import sub bumps & having the single reference to Sub 1 import as "Sub 1 Bump" is quite helpful for me actually. Nonetheless thought I'd report this as could cause some issues...
