Eos v3.2.3 has been released! To download the latest software, head to www.etcconnect.com/Eos-Software
Eos v3.2.3 focuses on critical fixes and optimizations for playback, synchronization in multiconsole systems, and other improvements. ETC recommends that users who have upgraded to v3.2.x move to v3.2.3 as soon as they are able, and users moving from v3.1.5 or earlier move directly to v3.2.3 when they are upgrading.
Playback, multiconsole, and synchronization bug fixes & improvements:
- Changing any Setup option could cause some address levels to snap to 0 and then back again.
- Extremely long file transfer times could be experienced on multiconsole systems.
- Undo could experience significant slowdowns.
- When the PSD is visible, it could slow down the fade engine refresh rate on very large shows.
- Channel Filters with a very large number of channels could cause low sACN refresh rate.
- Effects playback, out-of-sequence, and data management optimizations.
- General cue-firing performance improvements.
General improvements:
- In Patch > Universe Preview, the default view is now Port/Offset, and the controls have been moved into the UI.
- In previous versions, setting the per-channel shutter order in Patch > Attributes altered the shutters in the Augment3d model separately from the fixture profile. This has been fixed. A reminder that adjusting Augment3d shutters to match reality is done in the fixture profile editor. See this ETC support article: https://support.etcconnect.com/ETC/Consoles/Augment3d/The_Complete_Guide_to_Shutters_in_Augment3d
- Trackball use has been improved.
- Console sounds on Mac have been fixed.
- Over 100 bug fixes and improvements.
