I want to have my moving heads start slow and then slowly fade to normal speed after about 3 seconds. Is that possible in eos?
You can take multiple routes on this:
Cue 902 by default is a slow starting easing curve. If you want to look at, edit or make your own curve, they have their own display available (tab 21).
And i have one more idea.
use the Movement speed of the fixture if there is one in the profile.
