How can I make sure a show file saves in the same file path when two consoles (one primary Eos and one client Ion XE) are on the network?
I'm programming a show with two consoles as described above. I'm hoping to find a way for saving the show to happen in the same file path when you save from either console.
Is this a part of setup? Do I have to stay more specific than Shift+Update when I save from the client console versus the primary?
Thanks for any help!
